Write Text downwards
Jogy George
Message par Jogy George »
Is it possible write text downwards like:
J
O
G
Y
I know I can write one character, validate it then write the next one below and so on, but, its very time consuming!
Also, I would like to know if there is a shortcut to validate a text or a paste comand.
If these options are not available, would Antonio please be kind enough to include it?
Thanks for any help!
Cheers!
Re: Write Text downwards
Jogy George a écrit :Also, I would like to know if there is a shortcut to validate a text or a paste comand.
The enter key :)
JogyGeorge
Version de PhotoFiltre : 6.2.0
Processeur : 2.4Ghz
Mémoire RAM : 256
Jogy George
Message par JogyGeorge »
Boy! I must have been dumb not to notice that! :shock:
And anyways of putting the text downwards?
Please....
Thank you!
