First off: Can I do it with any font? Or just the kind that has spaces in the letters?
Second: Do I need the pattern to be big enough to fill the entire word/letter? Or can I somehow "stretch" the pattern to fill the letter/word?
Thanks!
How do I fill a word with a pattern?
Mushroom
Hi Mushroom
Only the fonts TrueType and OpenType compatible TrueType are able to be used wiht PF and PFS.
Try it with the both modes, so you do your self opinion.
- You can use a pattern in the text module at the second page
- you can use the button Transform in selection at bottom of the first page, and right clic in the selection : Outline and filling and you can select a pattern either to outline, or to fill the letters, either both.
The size of the pattern is indifferent.
Enjoy with trying it.
gpf
Re: How do I fill a word with a pattern?
I use a work around
first for ease of viewing, my opening screen is black
I create my own patterns or use the default ones
I go to the text screen
select a text and usually use about 24 or 36 size
I type something
then go to effects page
I select a fill pattern and the text is filled
I merge all layers
then go to any part of the black screen, select the magic wand, select invert, copy the text and paste as a new image
then its ready to use on any new image
Hope this works for you
I type something
I merge all layers
