carlo taradel
Messages : 271 Inscription : 10 oct. 2005 21:52
Version de PhotoFiltre : PF-PFS
Système d'exploitation : win XP pro- ubuntu_ breeze
Processeur : recycled from waste bin
Mémoire RAM : 1026
Message
par carlo taradel » 20 déc. 2005 15:30
well sometimes i can't move layer,if i have a layer in the background and i want move it forward, it does't move,same if i want exchange place of layer 2 with 3 ... i try different work around but with no luck
Quite big problem for me ,suggestion are welcomed
PS I can't even send screenshot to make my problem more clear ,(see topic "i can't take screenshot")
carlo taradel
Mémoire RAM : 1026
Message
par carlo taradel » 25 déc. 2005 18:43
It seem that is just the background layer that can't be moved,i don't understund why, but just by adding a new (empty,i mean whithe) background the problem was solved
Messages : 2950 Inscription : 08 mars 2004 18:17
Version de PhotoFiltre : Dernières de PF Free et PFS
Système d'exploitation : Windows XP Home SP2
Processeur : Athlon 64 3500+ non O/C
Mémoire RAM : 2x512 Mo en DC
Message
par FrançoisL » 28 déc. 2005 12:51
Yes, the background layer can't be moved (it's Antonio's choice). In order to move other layers make sure that the layer manager tool is selected
Bill
Messages : 162 Inscription : 20 déc. 2004 3:10
Version de PhotoFiltre : Free and Studio
Système d'exploitation : Coffee
Processeur : God Given Brain
Mémoire RAM : Not as well as when I was younger
Message
par Bill » 29 déc. 2005 3:58
Actually just about every program known to mankind does not let you move the background layer.
