Good evening to all,
I am still trying to dominate all features of PF and now I struggle with the filter Divers- Maximum & Minimum. Please see screendump http://www.oudje.nl/fr1.jpg
http://www.oudje.nl/fr2.jpg
What is the meaning of RAYON..... and what does this filter do..???
Please tell me if you can!
Thank you in advance,
Marga
http://www.oudje.nl/pf
Filtre - Divers - Maximum - Rayon
Marga
- Habitué(e)|Habitué|Habituée
- Version de PhotoFiltre : PF and PFS
- Système d'exploitation : W7
- Mémoire RAM : 3
Bill
- Version de PhotoFiltre : Free and Studio
- Système d'exploitation : Coffee
- Processeur : God Given Brain
- Mémoire RAM : Not as well as when I was younger
These filters especially the miimum work great for creating a painting effect. Much better results than the built-in paint effects.
Try something like this with a portrait.
1) Open Portrait
2) Filter / Noise / Dust Reduction (Medium)
3) Filter / Other / Minimum (Low or Medium)
4) Filter / Plug-in / Gravure (Contours + = Diaphragme 0)
5) Filter / Noise / Dust Reduction ( Low or medium)
1) Open Portrait
Marga
- Mémoire RAM : 3
filters minimum
Good morning Bill,
Absolutely gorgeous this effect....!!!
I tried it out on a flower (wet agapanthus in "summer" in Holland
Look here for the original http://www.oudje.nl/margaflower.jpg
and here for the result: http://www.oudje.nl/billpainting.jpg
Could I translate this instruction into Dutch and put it on the website for our classes?
See link below.... your name will be in it of course.
Have a nice day... rain again over here
Greetings, Marga
Greetings, Marga
Bill
Marga
- Mémoire RAM : 3
plugin Gravure
Good morning Bill,
Just a thing I noticed working with plugin Gravure - Contours:
1. I open an image in PF Studio
2. I duplicate the Background layer
3. I work on the layer (the copy of the background)
4. I put on the plugin Contours+ - diaphr. 1
5. NOTHING happens on the layer.... when I check off the visibility of the layer I see that the background has been modified with the effect...
Can you explain that..... ????
I just wanted to do it this way to be able to reduce the opacity of the layer (once finished with the effect) to let show through a little of the original.
I tried the same thing with other plugins of effects... but there it works normally...
Thanx for thinking for me....
and greetings from Holland.
Bill
