I'm taking on Production responsibilities on some books I'm involved in publishing.
I have limited knowledge of Photoshop and PhotoFiltre, but want to work with both.
I've so far cropped my pages (created borders) and sized them correctly (width and length). I want to be able to lay my pages on Templates provided by Indyplanet.com, so I can be sure my art is within the margins they should be, ect.
How on Photoshop and Photofiltre do I make my pages transparent, so I can lay them over the templates?
Any other tips for this process would be appreciated,
Thanks,
I didn't find the right solution from the Internet.
References:http://digitalwebbing.com/forums/showth ... p?t=164452
[Tom] I mask the link to a page without relation with the subject [/Tom]
Photoshop/PhotoFiltre
donnieclark
Re: Photoshop/PhotoFiltre
PhotoFiltre don't works with page but with image. To have an transparent image you must use a transparent format that support transparency (PNG or GIF for example). You can search on the web how to create PNG with transperency, i think there are lot of tutorials for this
