Animated GIF Preview option does not work
Niels
Version de PhotoFiltre : Studio 9.1.0
Système d'exploitation : Vista ultimate
Processeur : E6400 2,13GHz
Mémoire RAM : 2048MB PC6400
Message par Niels »
Hi,
I created a lot of GIF animations with studio, but now...when i click on ''preview'' nothing happens.
No page opens with a animation.
Reinstalled allready.
What to do?
Re: Animated GIF Preview option does not work
Hi,
The preview button calls a htm page.
You have to associate in "Windows Explorer/ Tools/Folder Options / Type of files" the htm files with your Web navigator.
More easy : search a htm file on your Hard drive and do a right clic : "Open With" chose your navigator and check "Always use this application to open such type of file"
Dernière modification par Tom le 01 juil. 2008 12:05, modifié 1 fois.
Niels
Message par Niels »
Ofcourse...
After i installed Firefox, everything worked fine again.
Thanks for help, also that helped. :clap:
Mészáros Tamás
Version de PhotoFiltre : PhotoFiltre Studio 10.13.1
Système d'exploitation : Win 7 Home Premium SP1
Processeur : AMD II X2 Athlon 265 3.3 GHz
Mémoire RAM : 8 Gbyte DDR3 2133 MHz Predator Kingston RAM
Message par Mészáros Tamás »
Imagelittle bug in the gif animator... :idea:[
Mészáros Tamás
This is to sign first and second and popup this window... :roll:
Mészáros Tamás
Vista problem.... :cry:
For the moment, no user reported this bug with XP. I think it's a compatibility problem with vista...
Some other users have this bug with vista/vista 64 ?
Mészáros Tamás
I dont't know. :oops:
No problem with Vista 32 bits.
But i wonder if the download of this PFS program was not-complete or corrupted ?
I think it's no internal reason that a 64 bits OS version can't display correctly a window which is displaid in a 32 bits version.
Mészáros Tamás
Preview problem. I think. I sent for Antonio in pfi. Bad download? No. I can not believe -sometimes this problem under 64 bit. :roll:
Mészáros Tamás
Sure :(
Mészáros Tamás
Problem...again... :(
Niels
Message par Niels »
It is possible ofcourse that this problem ocure with the 64 bits version.
Because i believe the Photofiltre that is available, only works correct on 32 bits.
Something about your computer: You have a 64 bits windows, with 64 bits hardware because otherwise vista won't Run properly. You can install a maximum of 4GB RAM memory, because 64bits is pretty heavy.
But you only got 1,5 GB! I really suggest you buy more RAM memory.
Also you got a VERY slow processor for the type of windows you have... :shock:
Mészáros Tamás
:?: crash in the preview... :oops: No You have got Vista 64 bit maximum memory 8 Gbyte...
(Home Basic) The aero style to eat lot's of memory... 8)
CPU 1.8 GHZ
1.5 Gbyte DDR 400
ASUS motherboard K8V-XE
250 Gbyte HDD SATA2 Maxtor
This isn't good? :?: :oops:
