I have just updated PF to 6.2.6 from 6.2.4, on XP SP2.
When I load PF, I get "This application has failed to start because libgfl211.dll was not found. Reinstalling the application may fix this problem." However PF loads and appears to run normally.
I have re-installed twice, but this has not cured it.
Has anyone else had this problem?
Missing libgfl211.dll
- Version de PhotoFiltre : 8.0
- Système d'exploitation : XP Pro
Re: Missing libgfl211.dll
I'm running v8.0 and get the same problem each time I run the programme. I ignore it now in light of no practical help in this forum.dreuby a écrit :I have just updated PF to 6.2.6 from 6.2.4, on XP SP2.
It appears to have no adverse effects.
- Mémoire RAM : 12 Go
Read this: viewtopic.php?p=12271#12271
