Italian translation: can I help you?
gaialodovica
Message par gaialodovica »
:D Hi!
Excuse me if I don't write in french... and if my english is very bad! :lol:
Luckily I understand enough both the languages.
I'm learning in these days to use PhotoFiltre: a marvelous software!
I would be happy to help you to translate plugins and other in italian language.
Ciao :wink:
gaialodovica
Lecteur
Processeur : Core Duo 2.2 Ghz
Mémoire RAM : 4 Go
Message par Lecteur »
vnt87
Message par vnt87 »
How do you create a .plg file anyway? My language was not listed and I wanted to translate this nice piece of software. But I haven't found a way to work with those .plg files yet.
i don't undersand, why do you want to create other plg file ?
just install it in your photofiltre folder and remove the english plg file
vnt87
Message par vnt87 »
No, what I meant was that I wanted to translate it into my own language (Vietnamese) which is currently not available yet as far as I know. So I'm wondering how I can achieve this?
Vietnamese is in progress, it will ba available at the end of this month :wink:
vnt87
Message par vnt87 »
Aw, somebody has beaten me to it? That's good to hear!
Thanks for the info ;)
==> Yes
the problem is that i need to make some changes in PFS and the language will works correctelly only with the futur PFS 801 (end of this month)
