Fonts
aljo
Fonts
Message par aljo »
What must do to have then font on PF...plz help mee!!!!!!!!!!!! :roll: :cry:
HI aljo,
PF use only the True Type fonts which are installed in the Windows/Fonts folder.
:arrow: Thanks to post in the Support/Elteno Forum
:arrow: You can use the above Search button with font or fonts as key word and select Support/Elteno as Forum.
