Feature Request: Vectors, Paths and Bitmaps ala Fireworks!
MarconeXIII
Message par MarconeXIII »
...and maybe also editable vertexes in point-to-point selection for fine-tuning.
Vectors would be cool. Reasons follow.
1. You can save an image with vector paths and fills, and open it for editing later without having to use bitmap tools.
2. Pixel-Perfect resizing!
3. Easy control on pixel-level antialiasing.
The list goes on....
Why not use any existing vector tool you ask?
Because no other image editing software in the whole world gets any near to the efficiency and smoothness of PhotoFiltre!
PhotoFiltre Rocks! - Small, Efficient, Powerful!
The developer knows what good software is all about.
Macromedia Fireworks started off so and so, ended up a total bloat, and now its going to be more bloated than anyone can ever imagine thanks to Adobe!!!
Long live efficient software like PhotoFiltre!
Thanks a lot Marcone,
I think Antonio, creator of PhotoFiltre, will be very pleased of your fine congratulations.
It's true, he has built a very intuitive and efficient tool.
If you try the Studio release, you will be very amazed once again.
http://www.photofiltre-studio.com/
To answer singularly to your request :
Several users, whose i am, have already introduced the same wish for vectorial tools.
I trust Antonio has well note-it. But for the moment, it seems he has also some other usefull thoughts in labor.
Come back as often as you like to see the last releases. :wink:
Enjoy still with PohotoFiltre. Best regards.
