http://photofiltre.free.fr/tmp/ContactSheet.zip
Voici une mise à jour de ce plugin, la plus part des paramètres sont conservés dans le fichier ini.
Je sais pas si c'est util de sauvegarder l'entête et le pied de page vu que ça change à chaque fois ?
Maj plugin Palnche Contact / Contact Sheet
- Membre d'honneur
- Mémoire RAM : 4 GB
Lecteur
- Mémoire RAM : 4 Go
Jogy George
1) Yes, it does not remember the last used folder.
2) Is it possible to give an option to REMOVE file extension?
3) At present, the user tells how many Rows & Columns are required. Is it possible for the user to also mention Page size ... for example. A4 Portrait, A4 Landscape, 600 x 800 or whatever. Problem now is if I put 15 column and 3 rows, it exceeds page size and when printing if I resize, quality becomes lower again!
4) For file date, can we use other formats also? ... MMM DD, YYYY or other customised formats?
5) Include photomasque for contact sheet.
The contact Sheet for Irfan View has very nice options. Can you please look at that and include those options?
Please ......
Thanks a lot!
Please ......
Thanks a lot!
- Membre d'honneur
