Fuzzy text
rustydog
Fuzzy text
Message par rustydog »
Greetings. Does any one else have problems with the text printing out unclear? If I have a pic with text in it already, then add my own text, the pf text is always fuzzy. Size doesn't seem to matter???
cheers
Bill
Version de PhotoFiltre : Free and Studio
Système d'exploitation : Coffee
Processeur : God Given Brain
Mémoire RAM : Not as well as when I was younger
Message par Bill »
A couple things:
1) Consider the Font you are using (stay away from real curly fonts)
2) Uncheck antialias in the Text Box Window.
rustydog
Wow! Thanks Bill. I uncheck the antialias box and it did make a difference. The text still pixilates (sp?). I think that’s what it’s called when you can see the little squares.
I love PhotoFiltre and I am amazed at what it does do for free. Is there any thing else I can do to not see the boxes. I don’t use fancy or curly fonts and use it for printing, nothing fancy but it would be nice if the text looked half way decent.
Cheers, Dulany
