Cannot use small fonts like silkscreen and sevenet
carnuke
Message par carnuke »
I have sevenet and silkscreen (http://www.kottke.org/plus/type/silkscreen/) pixel fonts on my system but PhotoFiltre can not use them correctly. I can select 8pt and antialiase off which is the correct setting but it dislays too large and distorted.
These fonts work OK in other programs. What can I do?
it's TrueType font ?
carnuke
yes its TT font and works ok in other graphic programs
i use standard windows function to display font, not photofiltre function. I don't undersatnd the bug. I will try the font this week...
carnuke
Thank you :)
carnuke
Small monofonts
Any news of this font problem? Has anyone got a small 8pt monofont that works with PhotoFiltre that I can download?
It needs to be really small and suitable for screen use like below. Thank-you
Input 6 in the size font? I tested and the size is correct.
With 8 or more the font is pixelised...
carnuke
Thanks for the reply. There is a problem here: When I open the text dialogue My font size option menu goes from 8-300 There is no option for 6pt
any suggestions?
thanks
you can enter 6 manually :wink:
carnuke
Dhur, so sorry I never knew I could do that.
Thank-you
