Some Questions
Pooh
Some Questions
Message par Pooh »
1. Why doesn't it have like an erasing tool?
2. How can I make a blend on it?
3. How do I get a plug in to work I mean I download it and then resarted Photfiltre but then it didn't work where it said it would.
4. How do you re colorize with out reving the whole picture..
5. And can you make HTML layouts on it?
That's all the question I have for now and this is an AWESOME Programee
==> only in the Studio version (http://www.photofiltre-studio.com)
==> use Edit > Fade after pasting an image or double click on a flotting paste to set alpha blend property
==> see the txt file in the zip archive of each plugin
==> not possible with PhotoFiltre
==> what exactelly ?
Pooh
Message par Pooh »
That is like to make a layout for a website..
Thanks for the help but also how do you do transparency with out messing the picture colors up?
