How to rotate a selected part of image - Reflection effect
Pruis
Message par Pruis »
Hello,
First I must say PhotoFiltre is an outstanding programme!
But I have some questions about the use of it:
1/ Is it possible to rotate an image or a selection of an image around its own middle? It's not easy to explane it clear but I hope you'll understand what I mean...
2/ Is it possible to integrate a reflection of a flash from a camera?
Example: Image
Pruis
Message par Pruis »
Forgot something:
I can't figure out what how to use next 4 icons (right hand side). What do they mean?
Tnx.
http://i91.photobucket.com/albums/k301/ ... loos-1.jpg
_
Hi Pruis,
1- Image/rotate/free on the whole image or on a selection
2- Look at this post :
viewtopic.php?p=66404#66404
3- If you try them, you will better understand what... :wink:
