How To PF Studio
Jack Douglas
Version de PhotoFiltre : 6.0.1
Système d'exploitation : Windows XP Home
Processeur : Pentium 4
How To PF Studio
Message par Jack Douglas »
I have the PF Studio 7.3 version installed, bought and registered. There is a newer version PF S 7.4, and I have downloaded the full version. My question is: Does this install over and replace the version I have now? I downloaded the Full Version of 7.4, shall I download another? Thanks.
:oops:
install over, don't remove old version
Jaume44
Système d'exploitation : w7
You
Message par Jaume44 »
Thanks Antonio!
You're the bomb.
Jack :D
