HELPPPP!!! I DONT GET HOW TO LOAD PLUGINS
lil00mish
- Version de PhotoFiltre : newest one
when i try to load the plug ins, it doesnt work!!! can somebody give me step by step instructions?! i know thats lame but i need help!!!!
Pooh
Prandon
- Version de PhotoFiltre : photofiltre
- Système d'exploitation : windows vista
- Mémoire RAM : alot
Re: HELPPPP!!! I DONT GET HOW TO LOAD PLUGINS
can you please just tell me step by step..
because i see no un-zip thing..
All needed for PhotoFiltre's plugins is on this page :
http://www.photofiltre-studio.com/plugi ... hp?lang=en
If you proceed manualy, when you have a zip file saved, double clic on it in the Windows Explorer,
and XP or Vista will help you to expand or unzip this file.
You simply have to specify the target folder : in our case : the Plugins folder in the PhotoFiltre's folder.
But generaly it's easier to use PhotoFiltre Plugins pack, on the same page of the official site.
