painting on the trasparent part of a layer
carlo taradel
Version de PhotoFiltre : PF-PFS
Système d'exploitation : win XP pro- ubuntu_ breeze
Processeur : recycled from waste bin
Mémoire RAM : 1026
Message par carlo taradel »
there is any way to paint on the transparent part of the layer :?:
After copy and pasting sometimes is needed to correct the new layer but i don't find any way to do it directly on the transparent part
Not for the moment :cry:
