The possibility of adding circular text and that way could have created labels of CD.
Thanks and good work.
How to do a circular text ?
supertitovic
Hi supertitovic,
you have just to download from PF web site, the plugin Paste inside and unzip it in the plugins folder of PF. Close PF and open again.
As his name don't notice it, you can paste the text arround a selected ellipse.
1- Copy the text
2- Select an ellipse
3- call menu/filter/plugin/paste inside
4- check arround
5- click on preview
6- play with length to spread your text or shorten it.
7- offset allows to move the text arround the ellipse
have a funny day.
1- Copy the text
4- check arround
5- click on preview
have a funny day.
- Membre d'honneur
Otherwise you can use the Text 2 Path plugin
