Internet Access
jimclatfelter
Système d'exploitation : Windows Vista
Processeur : AMD Athlon X2
Internet Access
Message par jimclatfelter »
I installed Comodo Firewall on my computer last week. Whenever I use PhotoFiltre Studio, it tells me that PFS is trying to access the Internet. It asks me to allow or deny access.
Why is PFS accessing the Internet?
Hi jim,
in my firewall (Zone Alarm) PhotoFiltre 6 or Studio are unknowned in the list of files having tried to connect the web.
However, when i click in the ? menu, on anyone of link, PF appears in the file list and the connection is asked for allow or deny access.
PFS don't access to Internet (only with the menu ? > Official web site)
Try to remove and install again...
jimclatfelter
Thanks for the information, Antonio. I don't use the ? menu, and it tells me PFS is trying to connect to the Internet anyway. I'll just tell the firewall to deny access to PFS. I'll reinstall as well.
