Selection Tool: How can I selection different parts?
mATriX2305
Message par mATriX2305 »
Hello,
first I would like to let you know that PhotoFiltre is a great tool but I´m missing or not finding an important function.
If i made a selection it seems that i have to do it in one step because if I would like to add another selection to the same picture the first one will be canceled. It´s hard to do a one step selection! Many graphic tool are offering the option to add selections to the same picture. Is it possible to something like that with PhotoFiltre?
Hope you understand what i mean.
Many thanks in advance
mATriX2305
Only with the Studio version using CTRL and ALT key
mATriX2305
O.K. thanks for your information. I downloaded and installed photo filtre studio a minute ago....
Can you please let me know where I can find the function to add a selection.
mATriX2305
Sorry...if found the function.
just using STRG will add and STRG+ALT will substract a selection!
Is it possible to fix this function or have I always to use this keys?
use allways this key :wink:
