Photofiltre_6.2.5
D_PF
Photofiltre_6.2.5
Message par D_PF »
I´d like to know, if Photofiltre editor 6.2.5 use some type of the compression during save file from JPG into the TIFF before edit. For example LZW. Older versions made large TIF files of same resolution, than now.
JPG files res. 3264x2448 were before about 20MB in TIF and now are files are in sizes 13-18MB.
Is possible change this? Thanks
yes LZW for Indexed and RGB format, RLE for Monochrom format
D_PF
Message par D_PF »
Where is possible to get previous versions?? Thanks
i don't understand...why do you want tiff without compression ?
with compression it's better !
D_PF
Message par D_PF »
Copression of TIFF files makes some problems during process on some DIGI_LABS. Better "pure" TIFF, or selectable compression, like in others editors. Thanks
Yes but uncompressed tiff is like bmp :wink:
then you can use bmp...?
D_PF
Message par D_PF »
Uncompressed TIFF is better for edit, not only for Me. When I consider to give this files for next process (compatibility). Someones could not update, and then I have to save else one as uncompressed i another editor.
for the moment in PF6, it's not a parameter, only in PFS :cry:
Perhaps in september...
D_PF
Message par D_PF »
OK, I am looking forward to new version. Thanks.
