Aspect ratio checkbox bug
peterbonge
Système d'exploitation : Win7 HP, 64-bit, DE
Message par peterbonge »
If you make a selection and open the manual settings there is a problem with the "Preserve aspect ratio" checkbox. By default it is on (with the the free version default is off) and it doesn't remember its setting.
why it is a problem ? i think it's better to set this option by default :wink:
peterbonge
Maybe. But that isn't really the problem. The problem is that the setting isn't saved. If I uncheck this option and open the manual settings again this option is checked again. If I uncheck this option it should stay unchecked. At least till I open another image or close the program.
And I think same options (of PF and PFS) should behave the same. So with PS the default option should be changed to be on.
