PF and VueScan
Thomas_BA
PF and VueScan
I am trying to use VueScan with PF, but the option 'Select Source' only shows me the Twain Software of my Epson Printer/Scanner. Is it possible?
Jaume44
- Version de PhotoFiltre : Studio 10
- Système d'exploitation : w7
- Processeur : Pentium (R) Dual Core
- Mémoire RAM : 4 GB
Type
Is this the type of software that is optioned under File > Print, then under the print options? Otherwise you may find the solution in the Vue Scan software under options or preferences. Hope this is helpful.
Thomas_BA
It dos not appear in the options File > Print and there is no possibility of configuration in VueScan itself. By the way VueScan is a profesional Scanner Software. Have a look at http://www.hamrick.com/
