smart curves for PFS
carlo taradel
Version de PhotoFiltre : PF-PFS
Système d'exploitation : win XP pro- ubuntu_ breeze
Processeur : recycled from waste bin
Mémoire RAM : 1026
Message par carlo taradel »
:) This plugin was created to add a curve tool to PhotoShop Element ,and so it could add a curve tool also to PFS
It's very intuitive has a very good preview, and is free.
Explain what are curves is complicated, but see what happen manipolating curves is quite simple with this tool...just plaay with setting watching the prevew to see a gallery of very different effect (and effects,i mean the curves could be saved and reused)
I post just 2 example but running it you can do much more...
original up down 2 different curves
link for download and more info http://free.pages.at/easyfilter/curves.html
Curve histogram and level,where is the difference :?: I really have no idea...
but it works
carlo taradel
Mémoire RAM : 1026
:( The server is down...if somebody need i suppose i can uoload somewhere
(i had to check ,it seem to me that author allow redistribuition )
Let me know, ...in case i must find a host for it
claudio-design
Version de PhotoFiltre : Photofiltre Studio 7.4.0
Système d'exploitation : Windows XP professional
Processeur : Pentium® 4 Intel
Mémoire RAM : 1024 MB (1 Go)
Message par claudio-design »
it's a very good plugin =)
Gracey
Message par Gracey »
I've used the curves tool in PSCS and would use it consistently over levels. It's the one thing I've truly missed in PFS, so I've downloaded your plugin and will give it a try. Thanks!
...now if somebody could figure out how to make actions work in PFs... :D
carlo taradel
Mémoire RAM : 1026
:D I like it becouse in a very intuitive way and with a really good preview allow to change the curves and at the same time adjusting the levels,and see also as histogram
And to load and save curves, really handy ...
