I had same problem with PFS i could find any clue.
Sometimes i could open and save several huge hi res images with no problem.
Sometimes just a low res image will crash (allways with Save as).
I never had crash with OPEN...only with SAVE AS .
PF unexpectedly closing
- Version de PhotoFiltre : PF-PFS
- Système d'exploitation : win XP pro- ubuntu_ breeze
- Processeur : recycled from waste bin
- Mémoire RAM : 1026
i changed in the Task Manager the priority of PFS.(now is Hight)
I can say that is a solution , i'm NOT sure about, but i can say that after i did it i never had this problem again.
(i'm not sure also becouse sometimes PFS was crashing opening and saving very little images...and i saved 30MB images with no problem...
However till now this solution seems working well)
- Habitué(e)|Habitué|Habituée
Antonio, yes XP SP2. Searching Microsoft's site I found this...
http://support.microsoft.com/kb/909486
which is a similar problem.
I've just installed the latest Photofiltre and started getting crashes when trying to open a selection that I'd just created/saved to file on the desktop BUT these are preceeded by the usual Windows error report send/don't send dialog.
Thre same problem occurs even after re-booting and without starting any other program.
Both problems seem to be exclusively related to the open/save dialogs.
