Brushes
Force
- Version de PhotoFiltre : Theres More ?
- Processeur : Pentium 4
- Mémoire RAM : n/a
Brushes
Is there like abstract brushes and an english tutorial Srry I dont understan french lol.
Hi Force,
For some tutorials, have a look on these sites :
http://www.photofiltre.com/
http://frontpagesolutions.com/photofiltre/index.htm
Yes, there is more releases for PhotoFiltre :
- 6... which is freeware,
- and Studio 8.... which is shareware 30 days :
http://www.photofiltre-studio.com/
For brushes, only PFStudio allows to add more.
Dernière modification par Tom le 16 nov. 2006 14:55, modifié 1 fois.
Force
- Mémoire RAM : n/a
magic1
tom, can u tell me how to (if possible) download other bruhes like the owns on this site
http://community.livejournal.com/100x100_brushes/
to phototfilter studio? i have version 8...
google or any web search engine is your friend.
On this forum too, the search button is available, and you can select add-ons section.
The brushes must be saved in png file and composed with square pictures assembled side by side.
Those created in another file type must be converted.
A little search with brush in support/elteno section gives some good answers to find freeware tools, able to convert psp or gimp files for brushes.
For memory, the brushes must be saved in the Brushes sub folder of the main PhotoFiltre folder.
Dernière modification par Tom le 07 déc. 2007 12:20, modifié 1 fois.
magic1
Sorry , but english is not my mother's language, and SMS or phonetic writing is quite cabbalistic for me.magic1 a écrit :so ur saying i CAN use those?AWSOME DUDE!
- You can use brushes with the advanced brush tool in the Studio release.
- under PF6 freeware, you can use them with PhotoMask
No i cannot explain how to do copy and paste, or extract a zip file.magic1 a écrit :ok, well can u please tell me what i have to do step by step since you know how?
Have a look on the tutorials of PhotoFiltre web site, or on basic tutorials for windows novices users.
I can only explain the brushes must be set :
- in Brushes folder of PhotoFiltre Studio main folder
- or in Masks folder of PhotoFiltre 6 (freeware) main folder.
magic1
thats ok, i learned french b4 english and my mother language b4 that, so u can give me the tutorial in french but with simple words.
first of all what ARE brushes, like you know those brushes on the brushes page on this forum... are they just pictures that you save in your picture file and then cut and crop and paste on top of your picture?
carlo taradel
- Version de PhotoFiltre : PF-PFS
- Système d'exploitation : win XP pro- ubuntu_ breeze
- Processeur : recycled from waste bin
- Mémoire RAM : 1026
They are as images with trasparent background (for this they must be in .png format...white is read as transparence)
Nozzle are...Multiple Images brush i mean each brush stamps a different image at each stroke.
Their use is simple...ad example image a "stone" nozzle...inside several image of stones ...you can use to fill up with natural looking stones a part of image
(if all the stones were identical they couldn't look too natural...)
If you create a nozzle the order could be set in a certain way (as example from big to little)...i didn't check yet how much control allow PFS over nozzle,
but a certain degree of random (randomness? i 'm not native english...) is part of the nozzle concept
magic1
ok, so then after that when i save it as png. the brush i open it on my image as a image? or does it just come in the photofilter brushes folder by itslef... i don't know how to add it to a piture, but you helped me with my my first step, thanx... if its not too much to ask, can u answer my question above?
magic1
