Question ?
Ming
Question ?
Message par Ming »
You have Advanced Paint Brush Tool in this program. They are just like brushes, kinda. ^^; My question is can you add you own styles, or can you only use the ones already up?
With the version 6 (freeware), you can not change advanced brushes
Ming
Message par Ming »
Is there any way you can though? :oops:
Hi Ming,
If the Big Boss him self says that you can not change advanced brushes in the freeware release PF6, there is no way ... :)
In the PF Studio release (shareware 30 days) it is possible to use your own brushes.
Have a look on this page :
http://www.photofiltre-studio.com/present-en.htm
And enjoy with PF or PFS.
