One more question about the PhotoFiltre "Selections&quo
Argentine citizen
Version de PhotoFiltre : 6.2.4
Système d'exploitation : Windows 98 2nd Edition
Processeur : Pentium III
Message par Argentine citizen »
The pdf file is blank when I download it and I get an error message. I made an update of the Acrobat Reader but it didn't help. Instead the English and Spanish tutorials in pdf files open perfectly.
I would like to know what the "Selections" tutorials says. Any suggestion?
I tested and it work. It's this link ?
http://photofiltre.free.fr/tutoriels/sel-pf-en.pdf
Argentine citizen
Yes, Mr. Antonio, it is that file.
It opens an alert that says:
"There was an error opening this document. This viewer cannot decrypt this document."
But I have no problems opening the tutorials of PhotoFiltre in the zip files:
http://photofiltre.free.fr/tutoriels/tu ... -pf-en.zip
http://photofiltre.free.fr/tutoriels/He ... panish.zip
There must be a difference between them, I guess.
Argentine citizen
Thank you for your nice PhotoFiltre program, Mr Antonio!
The original size of The Bubble Nebula that I used as avatar is 800 x 600 pixels and I resized it to 170 x 109 pixels without quality loss. You made a great job!
