Photoshop plugins
Jim Clatfelter
Photoshop plugins
Any plans to add the ability to use photoshop plugins? I'd love to use buZZ Simplifier and a few others right in PhotoFiltre.
- Membre d'honneur
Photoshop Plugins
Photoshop plugins
Great news that there will be photoshop plugin compatibility. I will be glad to pay for the new version. This is my favorite editor. I love that I can fade any filter or adjustment--even paste can be faded. So simple. No need to work with layers as in other editors. I really look forward to the shareware version. Jim
- Membre d'honneur
Jim Clatfelter
Plugins
Yes, I will buy the new version with layers. I seems to me that the current version is working in layers anyway. Since I can fade any adjustment or filter. I don't know of another program where you can do this. You can fade a layer is PSE2, but you can't fade a simple adjustment that isn't on its own layer. I like PhotoFiltre's method much better. So simple.
Of course I would like Photoshop Plugins even more. I use BuZZ Simplifier on many of my pictures. I use Virtual Painter as well. How about a PhotoFiltre SIMPLIFIER filter? That would be great.
Guest ..
PF is so easy. That is what I like about it. No hard work finding things and it's simple to use filtes and so many other things. In my way of thinking, this is what a lot of others should be doing with their programs. They should be simple without the mile high learning curve.
The first time I used PF, I was so pleased with it, I didn't bother with the other programs. Besides, they cost a bundle and have been around for years. One would think they would get easier, not harder. They have so many options, tools and etc, one can get / be lost in 10 minutes. Just to much bulk.
Antonio, you have done an excellent job with PF and I wish you much luck with it in the future. I to would buy the shareware version you mentioned.
Best Wishes ..
Guest / Mark
Best Wishes ..
Guest / Mark
snapshooter
Invité
Plugins .. etc.
No, I have never heard of it. Virtual Photographer - plugin system. I'll see if I can find it. If not, I'll post back and ask for details.
Thank You !
Mark
Thank You !
Mark
laurentriste
virtualPhotographer
Virtual Photographer from Optic Verve Labs
http://www.optikvervelabs.com
virtualPhotographer includes over 50 presets that automatically apply combinations of film grain, color modification, B/W, soft focus, high contrast and many artistic effects to achieve the same professional-looking images that used to take hours of photo editing.
snapshooter
TonyHomes
Invité
http://www.openexr.com/photoshop_plugin.html
is possible look this code and makeexternal plugin
josefina
Re: Photoshop plugins
What is the option in brushes in Photoshop that makes your brush narrow the longer you draw the line? I've seen my teacher use it before - but now I can't find it. It's in brushes in photoshop, and the longer your stroke is, the more it narrows away until it thins to nothing. Does anyone know what I'm talking about?
_____________________
yahoo keyword tool ~ overture ~ traffic estimator ~ adwords traffic estimator
