i've been tring for a while now, i've looked through what help i could find, but i can't work out how to load plugins, can someone please explain it to me simply?
[Tom] I tag the post as [Ref] Reference for easy research[/Tom]
How to download plug-ins ?
Hi and welcome,
You can find all the plugins for PF on this page :
http://plugins.photofiltre.free.fr/plugins.php?lang=en
At the bottom of the page, see how to install them.
A recent tool allow to download or update easily all the plugins you want specify. Download the exe file in French or English language at one of these adresses :
http://tutorielspf.free.fr/fichiers/pf-plug.exe
or
http://www.heisspiter.net/download.php?id=17&mode=http
or
http://www.heisspiter.net/download.php?id=17&mode=ftp
or
or
- Version de PhotoFiltre : PF-PFS
- Système d'exploitation : win XP pro- ubuntu_ breeze
- Processeur : recycled from waste bin
- Mémoire RAM : 1026
That solve the problem for all the PF plugin that you find in the plugin section on this site.
if your problem is about install extra plugin as Photoshop plugin
1 you can do it only with PFS not with PF
2 download ,and unzip them ,put in any folder you like,open PFS go in menu/
tool/preference look for 8bf. Using the dialog search bottom find the folder
restart PFS....Done
restart PFS....Done
- Version de PhotoFiltre : 6.2.3
photoshop plugin ...a good list on http://thepluginsite.com/
a few hints look for flaming pear mehdi xeno cybia
