Any help would be appreciated
How do I use plugins?? I'm sooo confused... please help.....
sweetiecat3
I have no idea what I'm doing... It's a different file type than the others once you download it. Now how do I use them, then?? I don't know how to change the file type. And please
don't try responding with fancy computer-talk LOL I won't understand you, most likely.
Re: How do I use plugins?? I'm sooo confused... please help.
Me too...sweetiecat3 a écrit :I have no idea what I'm doing...
Nobody could know of wich plugin you speak about.
And from where you have it downloaded ?
Can you give us the extension file type you've got ?
The best for the end :
computer-talk is not a fancy language but a technic one for being precise and understable by who wants any precise answer.
- Mémoire RAM : 12 Go
carlo taradel
- Version de PhotoFiltre : PF-PFS
- Système d'exploitation : win XP pro- ubuntu_ breeze
- Processeur : recycled from waste bin
- Mémoire RAM : 1026
i suppose you mean you don't know how to install them,pleaase have a look to this linkNow how do I use them, then??
viewtopic.php?t=6942
once installed to use them you just need to have a image open and call with a click the plugin you wish to try
