PhotoFiltre Studio - One Step Photo Fix
ckit
Version de PhotoFiltre : 11.4.2
Système d'exploitation : Windows 11 Pro x64 22H2
Processeur : AMD Ryzen 3 3300X
Mémoire RAM : G.Skill FlareX 3200Mhz 16Gb DDR4
Message par ckit »
Hi I'm a PhotoFiltre user and would like to know if PhotoFiltre Studio has a "One Step Photo Fix" function like Paint Shop Pro 9?
It's basically "Automatic Color Balance, Automatic Contrast Enhancement and Automatic Saturation Enhancement"
Thanks.
Hi ckit,
In PF6 or Studio release, two buttons are available : Auto Contrast, and auto levels for gamma, colour and saturation enhancement.
A new plugin : white balance adjustment is also very usefull for gamma, and colour.
In the Studio release, you can also blend several layers in Screen, or Multiply mode to enhance over or under exposed pictures.
An example with this tutorial :
http://frontpagesolutions.com/t/001/index.htm
ckit
Message par ckit »
Ok, thanks :)
