phpBB 2.0.20
Quoi de neuf à propos de PhotoFiltre ?
Heis Spiter
Mémoire RAM : 1536 Mo DDR
phpBB 2.0.20
Message par Heis Spiter »
Voilà, nouvelle mise-à-jour. Merci de me faire remonter tout problème rencontré.
Graham a écrit :
  • [Fix] Prevent login attempts from incrementing for inactive users
  • [Fix] Do not check maximum login attempts on re-authentication to the admin panel - tomknight
  • [Fix] Regenerate session keys on password change
  • [Fix] retrieving category rows in index.php (Bug #90)
  • [Fix] improved index performance by determining the permissions before iterating through all forums (Bug #91)
  • [Fix] Better handling of short usernames within the search (bug #105)
  • [Fix] Send a no-cache header on admin pages as well as normal board pages (Bug #149)
  • [Fix] Apply word censors to the message when quoting it (Bug #405)
  • [Fix] Improved performance of query in admin_groups (Bug #753)
  • [Fix] Workaround for an issue in either PHP or MSSQL resulting in a space being returned instead of an empty string (bug #830)
  • [Fix] Correct use of default_style config value (Bug #861)
  • [Fix] Replace unneeded unset calls in admin_db_utilities.php - vanderaj
  • [Fix] Improved error handling in modcp.php
  • [Fix] Improved handling of forums to which the user does not have any explicit permissions - vanderaj
  • [Fix] Assorted fixes and cleanup of admin_ranks.php, now requires confirmation of deletions
  • [Fix] Assorted fixes and cleanup of admin_words.php, now requires confirmation of deletions
  • [Fix] Addition and editing of smilies can no longer be performed via GET, now requires confirmation of deletions
  • [Fix] Escape group names in admin_groups.php
  • [Sec] Replace strip_tags with htmlspecialchars in private message subject
  • [Sec] Some changes to HTML handling if enabled
  • [Sec] Escape any special characters in reverse dns - Anthrax101
  • [Sec] Typecast poll id values - Anthrax101
  • [Sec] Added configurable search flood control to reduce the effect of DoS style attacks
  • [Sec] Changed the way we create "random" values for use as keys - chinchilla/Anthrax101
  • [Sec] Enabled Visual Confirmation by default
  • [Change] Changed handling of the case where a selected style doesn't exist in the database
  • [Change] Changed handling of topic pruning to improve performance
  • [Change] Changed default forum permissions to only allow registered users to post in new forums
ça bosse dur :wink:
Jepe
Version de PhotoFiltre : PF 6.4.0 & PFS X 10.3.0 beta
Système d'exploitation : XP SP3
Processeur : AMD Sempron 3100
Message par Jepe »
Aaah quel travail - Merci Heis pour ton engagement!
Jean-Paul
Apparament chez phpBB ils ont décidé de ralentir le rythme des MAJ, du coup quand il y en a ils y vont franco :D
Heis Spiter
En fait, ils préparent surtout la version 3 ;).
Bonjour Heis,
super boulot. :wink:
Petit problème d'affichage sous Mozilla, de l'image dans le premier post de ce sujet :
viewtopic.php?p=64027#64027
alors que je peux le faire afficher en cliquant sur le lien ajouté,
et que je vois toutes les autres du même hébergeur, dans leur post ???
Heis Spiter
Ce n'est pas un problème du forum, mais plus de Mozilla :oops:...
marcel51
Mémoire RAM : 1870 Mo
Message par marcel51 »
Sous Firefox (mis à jour ce matin) RAS.
Heis: bon courage lors de la sortie de la version 3.
Heureuses cloches à tous.
Lecteur
Processeur : Core Duo 2.2 Ghz
Mémoire RAM : 4 Go
Message par Lecteur »
pas de soucis non plus avec mon FireFox 1.5.0.2
*ScorpionS*
Version de PhotoFiltre : PhotoFiltre Studio ( la dernière )
Système d'exploitation : Linux Ubuntu 6.10
Processeur : 1,48 GHz
Mémoire RAM : 512 mo
Message par *ScorpionS* »
Même version que Lecteur, aucun problême
Pareil :wink:
Ah ben chouette pour phpBB 3, depuis le temps qu'ils l'annoncent :)
