4 point plugin
Charles
4 point plugin
Message par Charles »
Does anyone know of a filter/plugin that will allow me to creat a 4 point star effect on a candle, lights or rings if I happen to forget my cross screen filter? I have tried star maker and others in the VM Natural realm but none of them will do a 4 point star effect...7 or 8 points yes but not a good 4 point like a cross screen makes. I tried also sparkle but those are random and you cannot put just one sparkle where you want it.
Does such a plug in exist? I need to put a good 4 point effect in a candle or two or an engagement ring, etc.
Thank you.
je pense que c'est ce que vous cherchez.
Mi pensas ke vi povos trovi gxin cxi tie.
http://morepunkinstuff.tripod.com/filte ... parkl.html
Charles
sparkle filter
I already tried that sparkle filter..it does not work. There is no way to put just one sparkle where you want it..the places it does put a sparkle, the sparkle is not big enough...it is too small..I need to put just one sparkle on a ring or on one candle and make it big like a cross screen filter would.
I followed your link because I can only read english.
Il suffit peut-être de coller les étoiles sur un fond et de sélectionner celle qu'il faut et ensuite coller à l'aide d'un calque
la mosca
Message par la mosca »
peut-être avec le plugin particle?
(évidemment, cette utilisation n'est pas pertinente avec l'image utilisée, c'est juste pour l'exemple)
Aaron Zapashniy
Hi there!
Message par Aaron Zapashniy »
I'm newbie here and have to introduce myself. My name is Alex, 28 y.o. from Hungary. I have been looking for such kind of forum for a long time and at least I'm here. Hope that I'll become a member of this community and finally get the answers on all my questions, and may be my experience will be useful for all the ppl around. My Geek code GKDGRGBJ68QN.
Welcome Alex,
Are you also searching a 4 points star or have you post there by chance ?
wthrwthoutyu
Mémoire RAM : 512mb
Message par wthrwthoutyu »
A mask can be used to make a four point star effect.
I use this mask:
http://img.photobucket.com/albums/v642/ ... 2/Nova.gif
Make a selection, any size you like, and apply the mask with PhotoMasque to your selection.
Before:
http://img.photobucket.com/albums/v642/ ... before.jpg
After, with a four-point star added to the field:
http://img.photobucket.com/albums/v642/ ... 5after.jpg
carlo taradel
Version de PhotoFiltre : PF-PFS
Système d'exploitation : win XP pro- ubuntu_ breeze
Processeur : recycled from waste bin
Mémoire RAM : 1026
Message par carlo taradel »
:D Correct :!:
Or you can make a sparkle brush and use it...
or save the seletion of a nice spark load it and fill it with a circolar gradient :wink:
carlo taradel
Mémoire RAM : 1026
Aaron your site is really...very strange :!: :!: :shock:
