Plugin for 'Torn Edge Effects'
Thomas_BA
Message par Thomas_BA »
Is there a plugin available for making 'Torn Edge Effects'.
Example: http://jmmolina.free.fr/t_30531/SnagIt% ... s/Torn.jpg
Hi Thomas,
In the Studio release (shareware 30 days) exists a built-in filter :
Menu Layer/Border effect /Torn
Thomas_BA
Thanks a lot. By the way great program. Has all - i think - what i need. Will test it for a while.
Thomas_BA
I tried it via 'Menu Layer/Border effect /Torn. After inserting a new background layer it worked. But the torn efect does not look like a 'teared newspaper', like in my example posted above :(
Did you tried to apply this effect several times ?
