Orchid Layer
Jaume44
Système d'exploitation : w7
Orchid Layer
Message par Jaume44 »
My friend, Jes, sent me the photograph, and the layer was achieved using PhotoFiltre Studio by creating an alpha layer then selecting areas and cutting utilizing the wand and the polygon tool. The background color for the placement was selected with the eyedropper from the color in the center of the orchid. This type of color contrasting and matching is very effective. Thank you, Jes! :D
Fine pictures and work. 8) 8) 8)
