how do i use patterns?
soddit42
just installed PhotoFiltre and really find it a useful program. it's very easy to understand and use, except that i'm stumped on how to either access and/or use patterns. when i click on the "define pattern" or the "fill with pattern" links located under the "edit" toolbar button nothing happens and i can't find any mention of how to use patterns in the help file. can you please explain how i view, select and use a pattern? thanks. (there are lots of patterns in the pattern subfolder of my PhotoFiltre program file, so i know they're there--i just need to know how to get at them).
- Membre d'honneur
Hello,
Try to read this. It's a translation of a tutorial on my website. This translation isn't very good because it's google's. So, you have to understand "pattern" instead of "reason".
Dernière modification par FrançoisL le 20 févr. 2005 11:26, modifié 1 fois.
- Membre d'honneur
