How to show images in this forum gallery?
carlo taradel
Version de PhotoFiltre : PF-PFS
Système d'exploitation : win XP pro- ubuntu_ breeze
Processeur : recycled from waste bin
Mémoire RAM : 1026
Message par carlo taradel »
I know how to give a link, but i would like to be able at list to show a clickable thumbnail...I try with image shack , i upload ,copy the code, past in the forum and :cry: i see only links :shock: ...and i try that links ,they point not to any of my images.. but to the image shack upload page!!
I try to read again the instrution,i upload, copy, paste...and the end i had to delete my gallery post because it shows only 4 link for image shack upload homepage :roll:
But i see a lot of clickable thumbnails,even sort of slideshow...and huge big stamps,even large images in the gallery pages..
Where is the trick :?: really feel idiot,somebody could please help me to grasp the
solution :?:
Jaume44
Système d'exploitation : w7
test
Message par Jaume44 »
This is a pattern from my work. I went to Image Shack to the image, then to thumbnail code. There were two designated codes, the one labeled FORUMS is the one to copy and paste into your post.
Hi Carlo,
Have a look in your user profile of the forum.
You have de-activated the BBCode function in your messages.
So the signs as IMG or URL are not correctly red.
To morrow will be a better day. :wink:
carlo taradel
Mémoire RAM : 1026
:shock::oops: :lol: :D :!:
To complete my last post :
for a thumbnail which links to a picture :
adress_of _the_picture[/i]][img]adress_of_the_thumbnail[/img]
carlo taradel
Mémoire RAM : 1026
:?: Not very sure to have understund this ...for example
http://www.deviantart.com/deviation/29318730/ how to make it visible on the gallery forum?
(in example you could add blank spaces as http :// to make the link not working since this isn't the gallery forum,but i will really appreciate an example, ...english isn't my native language)
and [url.. or [URL .. :?:
Dernière modification par carlo taradel le 16 mars 2006 6:43, modifié 1 fois.
carlo taradel
Mémoire RAM : 1026
:shock: What happened :?: It's a miracle :?: how that image in the bottom of my last post on this topic pop up :?: :shock: It's almost 4 o clock in the night my brain is sleeping,i have to check better tomorrow :arrow:
Hi Carlo,
no you are not drunk, :wink:
i have put an example, that you had asked, in your message,
so you can edit your own post and see how matches the correct syntax.
carlo taradel
Mémoire RAM : 1026
thank you a lot :!:
carlo taradel
Mémoire RAM : 1026
:oops: I supposed still i miss some basic...i mean why here close to the bottom page viewtopic.php?p=61468#61468 only 2 images on 3 are displayed and nothing instead than one at the very bottom:?:
Hi Carlo,
you may edit the text you have posted, with the edit button(by chance) and compare basicely what matches with that does'nt.
After my first indications, the unique way to understand is to observ and try.
Keep cool and methodical. :wink:
carlo taradel
Mémoire RAM : 1026
i tried before posting,...and what puzzle me mostly is that a image that before was displayed now is no more visible...but i will try again
Hi Carlo,
I tried again :
- In the post with 3 pictures, the last link was correct, but before it, a control character like a line return was certainly wrong, for an unknown reason. I have simply delete all the characters between your text and the link, and it matches now.
This is just a little one of the plentiful delights in computing. :wink:
- in the last post, you have enclosured another marker :
[img]%20your%20link%20[/img]
You have just to erase both url to see directly the picture.
