blocked layers (unlocked but they can't move)
carlo taradel
Version de PhotoFiltre : PF-PFS
Système d'exploitation : win XP pro- ubuntu_ breeze
Processeur : recycled from waste bin
Mémoire RAM : 1026
Message par carlo taradel »
:roll: Sometimes with no any apparent reason some layers seems blocked
(i mean ,i can edit them, but no way to move them)
this happen with the lock option unchecked in the layer manager
I found a simple work around : menu\layer\free trasform , and without making any change i just press the okay bottom...after the layer is magically unlocked
So isn't a big problem...but maybe there is a quicker solution
Somebody had similar problem :?:
Hi carlo,
the best way to move a layer when it is already activated as current layer is to click on the tool layer manager,
or the shortcut key is W (like George :wink: )
carlo taradel
Mémoire RAM : 1026
:D yes,you are right!! :oops:
Hi Carlo,
it was just the bush which hides the forest ! :wink:
