Scanner not recognized
leavanni
Message par leavanni »
Own a Genius ColorPage HR6 V2 USB scanner and is not recognised by Photofiltre,but no problem with other similar software.Can you help.Thanks guys. :(
Jaume44
Système d'exploitation : w7
Plugin PF Studio
Message par Jaume44 »
Hello! There is a plugin available for PF Studio that should rectify this problem. That is, providing you are using PhotoFiltre Studio. :?
(Download and install "Import Twain" http://www.photofiltre.com/)
