Image explorer limitation
wonderwrench
Version de PhotoFiltre : 6.2.2
Système d'exploitation : XP Pro SP2 32bit
Processeur : K8 3000+
Mémoire RAM : 1 gig 2x 512 PC3200
Message par wonderwrench »
When using PhotoFiltre 6.2.1 there seems to be a limitation as to the number of thumb nails shown. I did not try to manually count them but the limit seems to be about 1k. I stumbled on this when looking for a specific file using the image explorer but could not find it.
Thanks
wonderwrench
6.2.2 does not change the above problem :cry:
No limitation, i can display 1000 images. I know it don't work correctely with some windows version but i don't know why...
wonderwrench uses XP Pro, so I don't think there is the known problem with this OS... :?
wonderwrench
Yes 1000 but no more. I may be dumb for having 1000 plus images in a given folder but I have 2 or 3 with over 3000. This makes the image explorer
unusable. Other programs handle this just fine, aka acdsee5 PSP9 etc.
Nice program though!!!
Antonio a écrit :No limitation, i can display 1000 images. I know it don't work correctely with some windows version but i don't know why...
