Automate/Batch problem
wonderwrench
Version de PhotoFiltre : 6.2.2
Système d'exploitation : XP Pro SP2 32bit
Processeur : K8 3000+
Mémoire RAM : 1 gig 2x 512 PC3200
Message par wonderwrench »
When using PhotoFiltre 6.2.1 to batch resize jpeg <.jpg> files it does not create output files when saving in jpeg format. It works if converted to other formats or when resizing .bmp to .bmp etc. Can anyone else reproduce this problem?
Thanks
wonderwrench
I just found out Version 6.2.2 came out today and it fixes the problem.
