Hi
I have the follow problem: I get several photos a day, wich I have to modify (eg. contrast, brightness, size,...). I'm looking for an automatism for that. I know the option "Bach processing" from the tool-menue. But, thats not exactly, what I'm looking for. I want an icon/button, wich I can press, an the the actual photo is automaticly modyfied.
Photoshop knwos this... but is there also a possibility with PhotoFiltre?
Simon
Batch
Hi Simon,
Had you seen in the last page of the module, that you can save your parameters ?
So to apply the batch processing on one image, you can do Alt+O+A, and if you have saved the parameters with the correct folder, you have just to select the file(s) you want process and validate.
I think Antonio has not in mind to make PF like the tool you said. Alternatively, I believe he could spend his time with other ways.
Dernière modification par Tom le 14 févr. 2006 14:37, modifié 1 fois.
- Mémoire RAM : 12 Go
Hi Simon,
Maybe a program as macroMaker could be convenient for this repetitive kind of work?
http://www.shareup.com/MacroMaker-download-13174.html
Simon_B
- Membre d'honneur
