I want to trasform a great number of files that have a board with angles to a board with round angles. It is possible to make this with automate/batch? (I tryed to insert an image to explaine me better but can not do this)
Thanks, Alessandro[/img]
[Tom]I move the topic from Support graphique to Support/Elteno[/Tom]
Automate shape
debelik
Hi debelik,
There is no tool to do exactly that yo want in the automate shape.
But ...
If your files have the same size, you can enlarge the workspace of the image and apply a pattern with a biger size than your original images which contains a frame with round angles.
Note that does not troncate the angles of the images but adds around a such pattern.
Evidently, take care to do some checks with a few number of files before processing all.
