Transparency color won't allow me to change it! Help!
Invité
Message par Invité »
Hello- I found Photofiltre last night, and am already very impressed, it is awesome! I really want to make some photomasks of my own, but I cannot get it to work. I made a B/W picture, and I want the center logo to be transparent, not the background. But when I try to choose a transparent color, the drop-down box for color automatically shows the background color and it won't allow me to choose any other color! I even tried changing the background color and it switched the transparent color to match! I have tried in both indexed color and RGB modes. What do I do? Help!
Click on the image to select the color
Frank Gayer
Message par Frank Gayer »
Hallo,
i have three colors in one picture and i`d like to have them all transparent. How can this work ??
Frank
MightyKitten
Version de PhotoFiltre : 6.1.1 NL / 7.0.1 NL
Système d'exploitation : Windows XP Pro/SP2
Processeur : Pentium IV @ 2,66 Ghz
Mémoire RAM : 704 MB
Message par MightyKitten »
Frank Gayer a écrit : i have three colors in one picture and i`d like to have them all transparent. How can this work ??
Ther is only one solution: make the 2 other colors first match the third color, then make that third color transparent.
You can switch one color to another with
Code : Tout sélectionner
menu Adjust > replace color
or
menu Adjust > Replace color range
Jeroen de Bruijn
Bill
Version de PhotoFiltre : Free and Studio
Système d'exploitation : Coffee
Processeur : God Given Brain
Mémoire RAM : Not as well as when I was younger
Real Easy to do!
Message par Bill »
Actually there is an easier way. See pics with instructions below:
1) Original Image:
2) Now click on the Transparent color button and then select the purple stripe with the eye dropper.
3) Now click on the Transparent color button again, select the green stripe with the eye dropper and then make sure Merge with current Transparency is checked.
Have Fun Bill
Great explanation Bill 8)
