tools are greyed
rbaldwin
tools are greyed
Message par rbaldwin »
I successfully opened and made numerous changes to two graphic files with out a problem. However i just opened my third file and now i find that most of the tools are not selectable, they are greyed.
Have i done something, or is something wrong with the file or ?? :(
Hi and welcome,
you can use the "Search" button above to do a research with key-word like "tools AND greyed".
So you can get this answer :
viewtopic.php?t=3986&highlight=tools+greyed
With pleasure to read you soon, best regards.
Dernière modification par Tom le 08 nov. 2006 16:20, modifié 1 fois.
You can also see my FAQ. I added the Babelfish translation button at the bottom of it :wink: OK it's not perfect but I'm sure it will help :)
rbaldwin
merci, exactement l'information que j'ai exigée. Et puisque le forum est en français et et je ne suis pas, transportez svp que le logiciel est un excellent outil.
thank you, exactly the information i required. And since the forum is in French and and i'm not, please convey that the software is an excellent tool.
Hi rbaldwin,
thanks for this appreciated feed back.
Have many satisfactions with PF. :wink:
