Request for Plugin - GREYCSTORATION
JogyGeorge
Version de PhotoFiltre : 6.2.0
Processeur : 2.4Ghz
Mémoire RAM : 256
Message par JogyGeorge »
Hi friends,
I was wondering if one of you (Alain, PF or someone else) could make a plugin for Photofiltre that uses the GREYCSTORATION image regularization algorithm. The alogrithm and its details can be found at http://www.greyc.ensicaen.fr/~dtschump/ ... index.html.
The source code of GREYCSTORATION is freely available and would be ideal for a number of purposes.
Looking forward to seeing this!
Cheers!
Jogy George
I don't find the code, only samples
JogyGeorge
Processeur : 2.4Ghz
Mémoire RAM : 256
Oh! I'm sorry, I don't really know too much, but on their Downlad site http://www.greyc.ensicaen.fr/~dtschump/ ... nload.html it is said that GREYCSTORATION is a part of the CImg Library, and is distributed within the CImg package.
The CImg Library can be found at http://cimg.sourceforge.net/.
The site also says "Victor Stinner has coded a GREYCstoration plug-in for the Gimp" and his site is http://www.girouette-stinner.com/castor/gimp.html. ...this is a French site
Hope that is helpful.
Cheers
Jogy
carlo taradel
Version de PhotoFiltre : PF-PFS
Système d'exploitation : win XP pro- ubuntu_ breeze
Processeur : recycled from waste bin
Mémoire RAM : 1026
Message par carlo taradel »
:roll: Never find any way to make that plugin working in Gimp on win(as far i know isn't a 8bf,doesn't work on photoshop,only in gimp and i suppose only in Linus).
And also in Gimp there is much better one (like resynthesizer,quite complicated to use but it really do sort of miracles
more info link for sample and source code http://www.logarithmic.net/pfh/resynthesizer
J'ai fait quelques tests avec GREYCSTORATION (version Win32 en ligne de commande) et je trouve que le résultat n'est pas très bon pour la partie "Image Inpainting" :cry:
carlo taradel
Mémoire RAM : 1026
maybe if you try resyntetizer you will be much more satisfied...interface is not very intuitive but at soon you understund how it work...well you will see :wink:
