Help writing text
ciprianhugianu
Version de PhotoFiltre : 2.6.0
Système d'exploitation : WINDOWS XP
Processeur : 2,5 GHZ
Mémoire RAM : 256
Help writing text
Message par ciprianhugianu »
Dear friends, I want to write some words near the image, not above the image in order to print the image and below, to print the text. Is it possible? Thank you.
Hi ciprianhugianu,
If you want to write some text near the image, you have to enlarge the workspace of image, but not the size of the original picture.
Right click on the picture and something like Size of workspace. So you can define how the picture will be enlarged and the colour of the new background.
ciprianhugianu
Mémoire RAM : 256
Is not completely clear
Dear Tom,
Thank you for your answer. If I right click on the image, I have this popup options:
Save
Save as...
Close
Cut
Copy
Paste
Clear
Selection shape
Image size...
Canvas size...
Fit image...
I could't find this option about workspace. Can you help me, please?
Ciprian
Yes Ciprian and sorry,
i hav'nt the english release installed yet.
In the list of the right click, you may use Canvas size, which is the image workspace in fact.
Image size is the way to reduce the weight of the picture.
You can try any options and go back, if the result is not welcome, by the undo button.
Get many satisfactions with PF and you will not regret the other graphic tools. :wink:
