I would be very sad, if I couldnt use this on X64
Photofiltre on Windows XP x64 ?
sylvio2000
Anyone tested this nice app sucessfully on XP 64 Bit ?
- Membre d'honneur
sylvio2000
- Membre d'honneur
Bill
- Version de PhotoFiltre : Free and Studio
- Système d'exploitation : Coffee
- Processeur : God Given Brain
- Mémoire RAM : Not as well as when I was younger
I never even thought to test it to be honest. I can tell you I'd do a dual boot if I were you. Even Microsoft Explorer included with XP64 comes in 2 versions 64 and 32.
Actually the gain in performance is great with a lot of programs. The problem is it does not recognize a lot of them during the install stage. That is were the big problem will be for a lot of folks. If the program has a 16 bit installer forget it the program will not install. While that may not seem like a problem to microsoft we all have our old favorites that no matter how far the technology goes we just can't get rid of them.
